z1 clutch line 25fork kit 93idler studs 30freeze plugs 5throwout bearing 29z1 oil cooler upgrade 220throttle body gaskets 6exhaust manifold gasket 40EGR gaskets 8oil filter tree gasket+o-ring 6main seal retainer gasket 2water pump 75coolant bypass (metal) 35heater core hose clamp 20PCV hose clamps 2.4.4 8AIV hose clamps 7.1 8AAC hose kit 44heater hoses 26PCV hose kit 842 -2.25 hose coupler 321.75-2.5 hose coulpler 32BDE engine mounts 390water pump pulley+belt 100Eagle rods 510ARP main studs 94Cometic 90mm head gaskets 190thermostat 18O2 sensor 198detonation harness 33oil pump gasket 2oil pickup 25oil pump 166SZ oil pan 595coil pack connectors 36timing belt kit 499plugs 50main seal 296 puck clutch 6003" exhaust 1050exhaust gaskets 3"x4 36exhaust gaskets 3"x2 20SZ testpipes 540JWT 500+ cams 1285SZ 740cc fuel kit 1425Ashspec intercooler piping 625Ashspec planar intake 395Sellin MAF 280MAF 150steering rack bushings 16Ashspec massives 800
